2003 Buick Century bent valves
125 MILES • 6 CYL • 2WD • AUTOMATIC
WAP11191
will my valves bend if my timing belt breaks?
Dec 29, 2009 at 11:51 AM
ERNEST CLARK
  • 1,730 POSTS
It depends on which motor you have under the hood. If you have any motor other than the 3800 V-8, then "Yes", your valves will bend.
With the push-rod version (3800), that won't happen.
But either way, you should replace the timing belt before it breaks. Why not spend a little to save a lot???
Dec 29, 2009 at 2:35 PM
WAP11191
thank you for information
Dec 30, 2009 at 2:13 AM
