2003 Buick Century Forgot to bleed system
130,000 MILES • 6 CYL • FWD • AUTOMATIC
SSGTMARATHON
Gentelmen,
I've just replaced my 2003 Buick Century's radiator, thermostat, hoses, and water pump, however, I forgot to bleed the system. I took the car for a test drive and it is still overheating and when I turned the heater on, cool air came out of the vent. Since I failed to bleed the system, could this be the root of the problem? If so, what is proper course of action?
Jun 3, 2010 at 12:50 AM
JALOPYPAPA
  • 467 POSTS
The usual method is to start with the engine cold, open the radiator cap and let it idle until warm. However, it seems unlikely any air in the system is causing it to continue to overheat. More likely an obstruction.
Jun 3, 2010 at 1:16 PM
