2003 Buick Century Car is making a propeller plane noise in
NCBEAST
Noises problem
2003 Buick Century Two Wheel Drive Automatic 99000 miles
I'm trying to figure out why the car is making a propeller plane like noise when I get over say 45 MPH.
It does not make the noise when I idle. Could this be tire balancing or struts?
Sep 15, 2009 at 2:55 PM
  • 110,248 POSTS
Does it change when you make turns?
Sep 28, 2009 at 12:32 AM
INTELLIBOY
[quote:2bb7dd9461="ncbeast"]Noises problem
It does not make the noise when I idle. Could this be tire balancing or struts?[/quote:2bb7dd9461]
I have the same exact problem with my 2003 Buick Century as well.
And to the person that replied and asking if it changes when making a turn, in my case, almost all of the noise disappear when I make a right turn or even a slight turn while driving. Turning left does not change anything. I hear buzzing noise on the right side, front of the car.
Any help would be appreciated. Thanks!
Oct 20, 2009 at 4:33 AM
  • 110,248 POSTS
If the noise changes when you make turns, the problem is most likely a wheel bearing. Actually, a right side wheel bearing to be exact. If you can tell if the sound is coming from front or rear will determine which one. It's usually the front.
Think about it. When driving straight, the vehicle weight is equal on each tire. When you turn right, most of the weigh moves to the left side of the vehicle removing it from the right side. If the sound goes away, that is because the bearing no longer has as much pressure on it.
Oct 20, 2009 at 4:55 AM
INTELLIBOY
[quote:8000352aeb="Jacobandnickolas"]If the noise changes when you make turns, the problem is most likely a wheel bearing. Actually, a right side wheel bearing to be exact. If you can tell if the sound is coming from front or rear will determine which one. It's usually the front.
Joe[/quote:8000352aeb]
Joe,
Thanks for the reply. You're right on! I asked a friend who knows a mechanic and suggested the same thing...wheel bearing. What you said about the weight distribution made a lot of sense.
To be honest, I was skeptical that I was going to get any help/advice from 2CARPROS that is going to help me with my car problem. Now that I have you guys and another mechanic confirmed what I suspected the problem was, I could get the parts and do it myself. Since that's going to save me money I would like to make a donation to the site. It's going to be a small donation because I'm currently unemployed, sorry.
Well...I just want to thank you guys for all the help and God Bless!
P.S
Let me know how I can make the donation.
Oct 20, 2009 at 7:24 PM
  • 110,248 POSTS
First, I'm glad you found the potential problem. We will always be here to help and try our best. As far as the donation, I'm not sure how to do it at this point, but I will turn it over to my boss, Ken, who will be able to direct you.
Thanks in advance for the donation, and if we can ever help in the future, let us know. There are several great technicians that work on the site, and if one can't help, there are others that can. Like I said, we try our best.
Thanks for using 2carpros.com,
Oct 22, 2009 at 1:43 AM
THIS IS MIKE
  • 686 POSTS
Hi Joe,
Thank you for considering us for a donation. You can click the donate button in the forum using paypal or your credit card. We really appreciate your contribution.
Thank you, from everyone in our 2Carpros.com family.
Oct 22, 2009 at 4:56 AM
EVETTE
when i first bought my buick, it was making that sound and I ended up having to put a fly-wheel on it.
Mar 19, 2012 at 1:20 PM
THIS IS MIKE
  • 686 POSTS
Those do fail occasionally as well.
Apr 2, 2012 at 11:14 AM
