air door actuator where is this located? when the control is placed in cooling mode for the drivers side heat comes out, when the control is placed in the same position on the passengers side cool air comes out. is it possible the air door actuator is not functioning correctly? is this vacuum activated?
Thank You
Thank You
Sep 17, 2010 at 1:42 PM
