2003 Buick Century
90,000 MILES • 6 CYL • FWD • AUTOMATIC
BRADS
When the Air Conditioner is on and I turn the fan on there is no air coming out or I should say very little. You have to put your face almost within 4 inches of vent before you feel it. Im not sure if its a switch problem, a vacume leak ? Any suggestions
Jul 23, 2009 at 3:14 PM
LOUT5369
  • 217 POSTS
When you move the mode control,does the air change direction,if you have it on defrost and you switch to floor, does it does it switch to floor?If it changes vacuum is OK,sounds like you have a bad blower resistor,You have no high blower either?The resistor is on the heater case,It will have approx 6 wires going to it,2- 7mm screws hold it down.
Jul 26, 2009 at 12:03 AM
