When you move the mode control, does the air change direction, if you have it on defrost and you switch to floor, does it does it switch to floor?If it changes vacuum is OK, sounds like you have a bad blower resistor, You have no high blower either?The resistor is on the heater case, It will have approx 6 wires going to it, 2- 7mm screws hold it down.
SPONSORED LINKS
Sunday, July 26th, 2009 AT 7:03 AM
