2002 Buick Century Caliper Bolts
BMURRAY74
I've got a 2002 Buick Century Custom w/ 148000 miles and a 3.1L V6. I am going to be replacing the front hub assemblies and I would like to know what size Torx bit I'll need to get the calipers off. Also, does Chilton's still publish repair manuals? I've been unable to find any of their manauls for anything newer than 2000. I think the Chilton's manuals put the Hayne's books to shame. Thanks for your help!
Oct 10, 2007 at 12:06 PM
CLY
  • 308 POSTS
You should not need a torx socket to do that repair. The caliper and the caliper bracket are both held on with 15mm bolts. The hub itself is bolted to the spindle with 13mm bolts. make sure that you use locktight on the bolts or replace them if called for...
Cly
Oct 12, 2007 at 9:09 AM
Suggested Repair
No Torx bit is needed to remove the front calipers. The caliper and caliper bracket use 15mm bolts, and the hub is bolted to the spindle with 13mm bolts. Apply thread locker to the bolts or replace them if the procedure calls for it.
Conversation Summary
The owner of a 2002 Buick Century with a 3.1L V6 asked what Torx bit is needed to remove the calipers while replacing the front hub assemblies, and also asked whether Chilton still publishes repair manuals. The expert said a Torx socket is not required: the caliper and bracket use 15mm bolts and the hub uses 13mm bolts. Thread locker or replacement bolts were recommended if specified.
