2002 Buick Century oily substance in cooling fluid
2002 BUICK CENTURY
ED TURNIPSEED
Engine Cooling problem
2002 Buick Century 6 cyl Front Wheel Drive Automatic
i have a 2002 buick centry ,i had the oil today and they found an oily substance in the coolant. there are no symtoms of the engine running hot idle is smooth car runs great. what can thi substance be?
Jul 11, 2009 at 4:09 AM
OBXAUTOMEDIC
  • 3,711 POSTS
If it looks like a milk chocolaty color most likely you have a blown head gasket.
Jul 11, 2009 at 4:30 AM
LOUT5369
  • 217 POSTS
Check your transmission fluid level,sounds like the trans cooler in the radiator is leaking,the transmission makes more pressure than the cooling system.If the cooler is leaking,the trans pressure would force fluid into the cooling system.
Jul 21, 2009 at 2:25 AM
