2002 Buick Century odometer/gear light
2002 BUICK CENTURY
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
JPIRIE2282
Good morning,
My odometer/gear light in my dash is completely out. I removed the dash panel to see if there was a bulb that needed replacing. In doing so, it looks like the odometer/MPH dash piece is all 1 unit. Is there a sensor or computer problem that could be causing that light to be out? The MPH and all other lights on the dash work, it is only the odometer/gear light. Is if it not a computer problem, how would you advise I fix it?
Jan 10, 2010 at 11:47 PM
SCOTTY DEE
  • 592 POSTS
You have to replace the Instrument Panel Cluster.
Jan 28, 2010 at 3:08 PM
