I was told by autozone the 2 codes showed indicated the coolant temp. and the o2 sensor before cat. converter was bad.OK I flushed engine completely,installed new thermostat,new coolant ,bled system .(the old thermostat looked good)then installed new o2 sensor (made by bosch).ok now I had battery dis connected ,with lights on for 10 minutes,great started car few times no trouble lights came on,sent wife to get inspection ,when she turned in to center the lights came back on.any ideas what else could have caused those combination of trouble codes,
Apr 5, 2009 at 3:29 AM
