low coolant sensor location?
SHERMAF
Where is the sensor located and is replacement difficult
Oct 25, 2009 at 12:36 PM
JDL
  • 16,098 POSTS
This sensor is located on the right side behind the radiator.
I am attaching all the info below from the manual.
However, while you are doing this, you may want to check the coolant and replace it while you are doing this. Here is a guide that will help with this.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Please see the info below on how to replace this and let us know if you have questions.
Thanks
Oct 25, 2009 at 12:48 PM
RANDALL1567
Low Coolant Sensor giving false readings because of intake gasket leak. I've had the gasket replaced but the Sensor is still acting up, showing Low Coolant when the coolant is not low. Moreover the Low Coolant light usually goes off once the engine has warmed up after three or four miles of driving.
My question is are the Low Coolant Sensor and the Engine Temperature gauge connected? Can I ignore the low coolant light and use the engine temperature gauge to determine when my engine is truly low on coolant and overheating.
Tks
May 26, 2021 at 5:24 AM (Merged)
DEJOLA
Hi. Came across your message about the low coolant sensor. I have a 2001 Buick Century with the same problem. Low Coolant light comes on even when coolant is not low.
If you've found the answer I'd appreciate knowing what it is.
Thanks.
John
johnandjanet@gmail.com
ROWTIEAR
  • 91 POSTS
Try removing the lowcoolant sensor from the reservoir bottle and cleaning it.
If that doesn't work, replace the sensor.
DOPPLERFX
I had the same problem shortly after correcting a lower intake manifold leak that had allowed oil to enter the coolant. The oil apparently fouled the sensor. I can't remember if I tried to clean it or not, but I do know that I ulitmately replaced it and the problem went away for good.
The sensor is on the passnger side of the radiator below the radiator cap. It is black and square and has a single plug at the bottom. It is held onto the radiator by a metal retaining clip. Remove the clip and the sensor pulls out of the radiator. Disconnect the wire by pulling carefully on the plastic lock and pull on the plug. Fluid will leak out to level of sensor. Drain or place catch basin below sensor plug to catch radiator fluid.
I ordered my replacement part from E-bay.
WOODSTOCKBIRD
My Buick had the low coolant light on intermitently. After three times in the shop (the catalytic convertor also went out) it is still on. Problem is the mechanic replaced the head gasket on that third trip, an expensive repair as oil was leaking into the coolant from the engine. He actually gave it back to me with the light still on. I gather he did not replace the sensor which was gummed up, so I took it elsewhere and they switched out the sensor. Now after a month the sensor is back on solid.
So my question is, since the sensor was replaced, could there have been residual oil still in the coolant which is now gumming up the new sensor? Is it even possible to replace the head gasket without draining off the old coolant? I hope it would be very unlikely that they could have screwed up the repair in such a way as it is still leaking...I can't afford any more repairs. I would appreciate your input.
Thanks
LEGITIMATE007
  • 5,121 POSTS
your supposed to drain and replace the coolant when doing a head gasket. your coolant temp sensor may not be the problem anymore. take it to autozone or advanced autoparts/checkers for a free computer scan, so that you can get the trouble codes and bring them back to us. we'll take it from there
WOODSTOCKBIRD
Thanks for your reply. Yeah, well I would have thought they would have automatically flushed out the coolant, but it turns out they did not. It was flushed prior to the repair when he tried some sealant, but the light came back on within a few weeks, so clearly the oil was still leaking in. Now after the fact he tells me he didn't want to have to charge me for flushing it out since it wasn't so bad that it would effect performance. I assumed they had.
Of course this left the low coolant light still on. Granted I suppose it makes no difference, but I think they should have flushed it, or at least discussed the options. So now I have a second sensor that I had put in that is gummed up. I'm sure the second mechanic assumed that it has been flushed also and they had just tried cleaning the sensor and had not replaced it.
I thought I would have the coolant flushed somewhere else and then figure how to put a new sensor in myself. It looks to me like the input is a few inches down on the engine side of the radiator, but I'm going to pick up a manual to get the exact procedure. Do you think that would be a good course of action? Also I imagine a flush might not get all the residual oil out and the problem could possibly recur anyway. Would you personally even bother?
Thanks for the help man.
Tony
LEGITIMATE007
  • 5,121 POSTS
oh yes its worth it. go ahead and flush it and put the new one in. but first go to autozone and have them reset the engine light for free. drive it and see if it comes on again if it doesnt then everything is ok. if it comes on then do your flush and change the sensor
WOODSTOCKBIRD
Thanks for the response. I gather you have to build up some points before you can leave a feedback, I will when I can. Tried to give you one, but I have oly 0.1 points thus far.
I'll take care of the coolant light issue this week coming.
By the way, another odd thing happens sometimes on this same Buick. I've had the brakes checked several times and they tell me they are fine. Occasionally the car makes a small groaning noise when braking at very slow speed. When this happens the ANTI LOCK, TRAC OFF and SERVICE VEHILE SOON (not check engine) lights all come on at once, but go off again when the vehicle is restarted. The only code that ever registers is that the wheel has slipped, like when it spins on gravel, but of course that is not the case. Odd that, I've always assumed there was some sort of sensor malfunction there, perhaps intermitant. Although the noise sounds like something straining or humming, which I gather could be the anti-lock motor? Never happens when a mechanic looks at it. Ever hear of anything like that?
A while back I whacked into a baby deer and although there was no damage to the car, this happens a bit more frequently since. (Both this and the coolant issue predate the deer incident).
Thanks again,
Tony
LEGITIMATE007
  • 5,121 POSTS
yeah its probably the actuator motors, but you should check the tone rings on all of the axles to see if some of the teeth are chipped. or if the sensors are loose
