2002 Buick Century Heater and A/C blower does not work.
JKESTRELL
Heater problem
2002 Buick Century Automatic 107545 miles
First problem was blower stayed on after I shut car off without me noticing and drained battery. Jump started Pulled fuse and it shut off. Checked fuses--all OK. Same thing next time I stopped so I again pulled fuse and plugged in when ready to drive. Next the blower shut off when car shut off but now only high blower worked for heat or A/C. Then today all blowers stopped. Checked all fuses. No problems. What is going on? I can live without the A/C but what about when the NH fall and winter hit?! Any info would be greatly appreciated!
Sep 2, 2008 at 6:10 PM
JALOPYPAPA
  • 467 POSTS
I'd check the resistors for fan speeds below high. Maybe a short and then open connection. Should be a small cover plate attached to the firewall surface of the ductwork near the blower.
Sep 3, 2008 at 4:15 AM
