2002 Buick Century Headlamps
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
GSBEYER
Passenger side headlamp not working. Bought new bulbs, still doesn't work. Only getting 3 volts at the connector at back of the light. It usually starts at 5v and falls to 3v. Only passenger side. Ideas?
Aug 30, 2009 at 8:09 AM
JDL
  • 16,098 POSTS
did you check for voltage at the connector with the connector unplugged? If that shows low, check the right hand headlamp fuse, under hood fuse box. Pull the fuse, check for voltage.
Aug 30, 2009 at 8:21 AM
