2002 Buick Century fuel gage problem
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHESIRE22000
I have a 2002 buick century with 130kmiles on it. Something wierd is happening with the fuel gage. When I start the engine it might jump to full and a few seconds later go to zero and go up and down slowly in a jerky fashion, usually ending at about where it should be. For instance if the tank is half full it will sort of end at half full but jerk a little from time to time up or down a little bit. One thing I noticed when I go to start the engine -before I start it when I turn the key to the run postion with the starter not yet engaged, the gage goes up to the correct position in a jerky motion. What might be wrong?
Mar 26, 2009 at 1:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty fuel level sending unit ..
Thanks for using 2CarPros.com!
Mar 26, 2009 at 4:53 AM
