2002 Buick Century Dash Lights
120,000 MILES • 6 CYL • FWD • AUTOMATIC
TATER72510
Our car keeps blowing the 7 amp fuse for the dash lights. The headlight switch works and it will operate the dome lights in the car with no problem.
Nov 4, 2008 at 11:07 AM
  • 110,251 POSTS
Hi:
The insturment cluster on your car is a sealed unit. If there is possibily a problem, you will need to remove the cluster and have it checked by a dealer. They have the correct tools to check it. If there is an internal problem, the cluster will need replaced.
Nov 12, 2008 at 11:12 AM
