2002 Buick Century Cylinder 5 misfires
DJPLUCKG
  • 5 POSTS
Engine problem
2002 Buick Century V6 Two Wheel Drive Automatic 135000 miles
I took My Bucik century to Autozone to have the code read. it came up as cylinder5 misfires. the rep said that it could be a bad spark plug or the wire can be Bad. Is this true? He also said i need a oxygen sensor.
Dec 8, 2007 at 1:49 AM
BMRFIXIT
  • 19,053 POSTS
[quote:6c94132c24="djpluckg"]Engine problem
I took My Bucik century to Autozone to have the code read. it came up as cylinder5 misfires. the rep said that it could be a bad spark plug or the wire can be Bad. Is this true? He also said i need a oxygen sensor.[/quote:6c94132c24]
YOU HAVE OVER 100K ON IT
I WILL DO A COMPLETE TUNE UP PLUGS WIRES AND FILTERS AND RESET CHECK ENGINE DRIVE FOR ABOUT 50 MILES AND OR FEW DAYS
YOU MAY NOT NEED AN O2 SENSOR
IF TUNE UP IS BAD DO THAT FIRST
GOOD LUCK
Dec 8, 2007 at 4:33 AM
DJPLUCKG
  • 5 POSTS
thanks i will check out all of the possible problems. i havnt did a complete tune up on it. just plugd and wires
[quote:2e78afc0ab="BMRFIXIT"][quote:2e78afc0ab="djpluckg"]Engine problem
I took My Bucik century to Autozone to have the code read. it came up as cylinder5 misfires. the rep said that it could be a bad spark plug or the wire can be Bad. Is this true? He also said i need a oxygen sensor.[/quote:2e78afc0ab]
GOOD LUCK[/quote:2e78afc0ab]
Dec 10, 2007 at 7:48 AM
BMRFIXIT
  • 19,053 POSTS
[quote:616c8ba4f3="djpluckg"]thanks i will check out all of the possible problems. i havnt did a complete tune up on it. just plugd and wires
[quote:616c8ba4f3="BMRFIXIT"][quote:616c8ba4f3="djpluckg"]Engine problem
I took My Bucik century to Autozone to have the code read. it came up as cylinder5 misfires. the rep said that it could be a bad spark plug or the wire can be Bad. Is this true? He also said i need a oxygen sensor.[/quote:616c8ba4f3]
GOOD LUCK[/quote:616c8ba4f3][/quote:616c8ba4f3]
check the wires
again
also check the coil
good luck
Dec 11, 2007 at 5:31 AM
