2002 Buick Century Battery Will Not Stay Charged
2002 BUICK CENTURY
145,000 MILES • 6 CYL • FWD • AUTOMATIC
ZSHAW8442
My battery will not stay charged. I have replaced the battery twice, so the battery is new. I have also replaced the alternator with this problem came up because it was weak. Even after a brand new alternator which I also took in to get tested and a brand new battery, the car still will not keep the battery charged. Is there something that could be keeping this from happening like a fusible link, or could i just bypass all the wires and hook up a cable straight from the battery to the alternator with no side effects? I am assuming that there is an electrical problem between the alternator and the battery since both are brand new and working. Thanks for your time.
Nov 24, 2008 at 1:29 PM
DOCFIXIT
  • 18,828 POSTS
You most likely have a drain caused by a circuit being powered up with key off. You need to have a battery drain test done to isolate the circuit and repair.
Some common items are glove box light, vanity morror light, trunk and engine compartment light
Nov 29, 2008 at 9:01 AM
