2002 Buick Century ac fan only works on high
2002 BUICK CENTURY
54,000 MILES • 6 CYL • 2WD • AUTOMATIC
BARBARA TOMLINSON
My fan for the ac will only run in high speed Is it the switch or the resistor that needs to be replaced and where will I find the part in my car.
Jun 19, 2008 at 11:08 AM
JALOPYPAPA
  • 467 POSTS
Usually, the high blower speed is the only one that doesn't go through the resistor, so I'd suspect the resistor. It may be in the ductwork, on the other side of an inspection plate with wires leading to it, on the firewall near the blower motor.
Jun 21, 2008 at 2:54 PM
