2001 Buick Century TURN SIGNAL INDICATOR, CRUISE CONTROL
30,000 MILES • 6 CYL • FWD • AUTOMATIC
BYFLEET
Cruise control is engaged. Turning the turn signal indicator to the "right turn" position disengages the Cruise control. Right side turn signals (front and rear) appear to work normally.
Cruise control is engaged. Turning the turn signal indicator to the "left turn" position does NOT disengage the Cruise control. BUT, the internal left turn turn indicator flashes rapidly. The left front turn indicator flashes rapidly. The rear turn indicator does not illuminate.
Mar 14, 2008 at 4:36 AM
2CARPRO JACK
  • 11,533 POSTS
The fast flashing and non-opeatin are most likely bulb problems. The cruise is probably the wiring from the multi-function switch where it goes into the column getting frayed/broken from usage, seen it before
Mar 15, 2008 at 1:40 AM
