2001 Buick Century Service engine light is on
60,000 MILES • V8 • 2WD • AUTOMATIC
WILSONLSU
Teh SEL is on (and had been on for 10 months) - I have taken it to 3 different shops and they have run diagnostics. They all report "no code appears".
Any suggestions - it will not pass inspection with teh SEL on.
thanks
Aug 19, 2008 at 2:20 AM
BUDDYCRAIGG
  • 2,262 POSTS
3 different shops have said there are no codes???
i would think that there has to be a problem with the wiring or the ECM is freaked out.
if you're just trying to pass a sniff test, can you take the light bulb out before you get there?
Dec 15, 2008 at 6:24 PM
