2001 Buick Century ignition
88,000 MILES • 6 CYL • FWD • AUTOMATIC
GOLFIDO
  • 5 POSTS
I get a 1374 code. It is an ignition problem. Car is hard to start then runs rough when it does run. However it runs great at times. Is this code the coil pack?
Jul 6, 2008 at 12:05 PM
JDL
  • 16,098 POSTS
It's a crank sensor code. My information shows two crank sensors. I'd check the 7x sensor first, that sends the signal to the ignition module. Might be the sensor--wiring circuit or connector.
You might also check the other one.
Jul 7, 2008 at 2:34 AM
GOLFIDO
  • 5 POSTS
Thank you for responding. I am in the middle of replacing the crank sensor behind the crankshaft pully. It looks like a 1/4 moon. The other one is cylinder like. Where does that one go?
Jul 7, 2008 at 7:00 AM
JDL
  • 16,098 POSTS
You should have tried to do some testing, first. The code won't tell you if the problem is the sensor-- wiring circuit-- connector or whatever.
The magnetic reluctance crank sensor may be on the back side of the engine block, down low. The wiring harness goes to the ignition module. The ignition module is under the coil pack. There should be two wiring connectors on one end of the module, the smaller connector should be for that crank sensor, you can follow the wiring. The primary colors are purple and yellow.
Jul 7, 2008 at 7:46 AM
GOLFIDO
  • 5 POSTS
Thanks again for responding. I am not that swavy when it comes to electrically testing components. My father in law, since retired from 30plus years of automotive repair, questions the fuel pump. He states that pressure could be low causing misfire codes. I will check pressure. Do you know the proper fuel pressue for such an engine. 3100 v6 buick centuy, 2000. I like that idea also due to the fact that it kinda runs only when gas pedal is pumped while engine is turning over. Then will kinda run only at higher rmps. Once at idle she dies.
Jul 7, 2008 at 10:57 PM
BTHOOD
Key On Engine Not running 52 to 59 PSI.
I am not certain about Buick, but I had a 3.9 Liter Ford that called for 35 PSI with the key on/ engine off. I found 30 (+/-) PSI at the port. THis engine would not start or run. When I replaced the pump, it run like a new one. I hope this helps.
Brian
Jul 7, 2008 at 11:17 PM
GOLFIDO
  • 5 POSTS
Are we having fun yet!? 2 New crank sensors, 1 new camshaft sensor, 1 new 02 sensor, 1 new fuel pump. same problem. Only thing left is the ignition module under the coil pack. If not that, cumputer?
Jul 9, 2008 at 11:21 PM
DENNYP
  • 1,824 POSTS
It's most likely a bad ignition module or a coil pack that is arcing to the module.
Jul 11, 2008 at 6:36 AM
GOLFIDO
  • 5 POSTS
It was the ignition modual. Runs great! still somewhat shaky tranny, but rolling.
Jul 11, 2008 at 8:48 AM
