2001 Buick Century fuel shut off.
POSIDYNE2
Engine Performance problem
2001 Buick Century 6 cyl
The 2001 buick century ran out of gas. Since it will not start. I was told it had a fuel shut off to protect the fuel pump when this happens. If this is true where is it.
Mar 20, 2010 at 8:19 AM
JDL
  • 16,098 POSTS
There is no shut-off that I'm aware of? You have gas in it, correct? When you first turn the key on, no crank, can you hear the pump run for a few seconds? Did you check all applicable fuses. At the fuel pump connector, check for voltage and ground, with the engine cranking. Gray wire is voltage, black wire is ground.
Mar 20, 2010 at 8:49 AM
