Can't locate temperature gauge wire?
57,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOPPLERFX
I just performed a lower intake manifold replacement this weekend, and the only thing left undone is the connection to the temp sensor near the manifold thermostat. Car is running great, but now I have a temp sensor high indication as a result of this missing wire.
My fear is that the missing connector was unknowingly folded beneath the upper pleum when resinstalled, but I could swear all the wiring that feeds the injectors and other items was faithfully routed and connected.
I performed an exhaustive search with no luck, so I'm at the point of removing the upper untake plenum again to search for my missing connector. But before I do, I was wondering if anyone could be so kind as to give me vector. TIA
Mar 11, 2009 at 6:41 AM
DOCFIXIT
  • 18,828 POSTS
Look for a yellow and black wire with connector. ECT is located top left side engine below throttle body.
Mar 11, 2009 at 7:12 AM
DOPPLERFX
I know where the sensor is, I can't find the wire that connects to it! Thanks.
Mar 11, 2009 at 7:15 AM
