DTC is P403 & P405. Engine lacks acceleration power but will motor along at low throttle position and even gain speed to about 68 MPH total. On full throttle it bogs down and, at times, will not pass 35 MPH. I have Autoenginuity and it shows the timing to be around 15-20 when running somewhat OK and then at 40-44 when it bogs down(I can supply the spreadsheet of activity if you desire).
The EGR valve on the valve cover seems to be unclogged - the metal weighted plug inside moves easily when shook. Does the EGR sensor need replaced?
SPONSORED LINKS
Wednesday, August 15th, 2007 AT 1:04 AM
MECHANIC
The EGR valve on the valve cover seems to be unclogged - the metal weighted plug inside moves easily when shook. Does the EGR sensor need replaced?[/quote]
SIR, YOU MUST BE TALKING ABOUT THE PCV VALVE. IT IS NOT THE EGR VALVE
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0405 Exhaust Gas Recirculation Sensor A Circuit Low.
