2001 Buick Century 2001 Century 3100 surging.
2001 BUICK CENTURY
203,000 MILES • 6 CYL • 2WD • AUTOMATIC
HIRIZE
  • 7 POSTS
My 2001 Buick Century Custom (3100 engine) surges. It feels like a firing problem in that it is bogging down as if it is miss firing then returns to normal. We have recently put a gas filter on it so I don't think it is the gas filter stopping up. Any suggestions as to what may be causing this problem...Thanks.
NOTE: I'll be happy to adjust the donation when someone can help me out as I didn't know how much to donate to be fair...Thanks again.
Aug 9, 2009 at 4:14 AM
BRIAN 1
  • 1,030 POSTS
I would check fuel pressure,should be 52-59psi and also check the spark plug wires at the ignition coils,they burn and get rusty real easy,very common.it both could cause a missfire.post back with what you find.
Aug 9, 2009 at 9:19 AM
HIRIZE
  • 7 POSTS
[quote:ae75f39b19="brian 1"]I would check fuel pressure,should be 52-59psi and also check the spark plug wires at the ignition coils,they burn and get rusty real easy,very common.it both could cause a missfire.post back with what you find.[/quote:ae75f39b19]
Thanks...It may take a day or two to check it or have it checked and post again but I will as soon as I can...thanks again.
Aug 9, 2009 at 11:58 AM
HIRIZE
  • 7 POSTS
[quote:c98750cf4c="brian 1"]I would check fuel pressure,should be 52-59psi and also check the spark plug wires at the ignition coils,they burn and get rusty real easy,very common.it both could cause a missfire.post back with what you find.[/quote:c98750cf4c]
It appears the problem was coming from a spark plug wire not connected well at the coil. Thanks for your help.
Aug 18, 2009 at 2:39 PM
