2000 Buick Century Turn Signal
2000 BUICK CENTURY
160,000 MILES • 6 CYL • FWD • AUTOMATIC
ROBFROMABOVE
Just recently the right turn signal, when activated, "clicks" twice as fast. When I went to inspect all of the lights, I noticed that the rear right turn signal does not activate, but the front does. On my model of car, the brake light and turn signal are the same, and the brake light -is- functioning. So the bulb isn't out, and I looked at the instruction manual and there doesn't appear to be a fuse for specific turn signals, so what could be the problem? Is there a solenoid somewhere in the wiring that activates the turn signal that's blown?
Dec 1, 2009 at 7:25 PM
DOCFIXIT
  • 18,828 POSTS
First brake and turn are same bulb but it has two fillements so check bulb see if a fillement it burnt out.
Dec 2, 2009 at 2:52 AM
