2000 Buick Century Transmission Problem
115,000 MILES • 6 CYL • FWD • AUTOMATIC
SANBORNFAMILY
I have a Buick Century Custom. My problem is this...
Sometimes the Transmission jerks when changing gears. On take off it will sit there and vibrate if you hit the gas to hard instead of spinning freely. I read a message on you site from someone else that had the same problem. He had the transmission rebuilt and it still is doing it. He said someone told him it could be the Computer I was wondering what you think on the matter!
Thank you for you time.
Jan 24, 2008 at 10:08 PM
BMRFIXIT
  • 19,053 POSTS
[quote:2e00a4060c="sanbornfamily"]Transmission problem
2000 Buick Century 6 cyl Front Wheel Drive Automatic 115000 miles
Thank you for you time.[/quote:2e00a4060c]
For the tranny to give its best the engine has to be at it best
I would check the engine tune up 1st and its operation
then I will move on to the tranny
make sure engine fine tune
ignition wires and fuel and all
check motor and tranny mounts
Jan 25, 2008 at 8:48 AM
