2000 Buick Century starting problems, leaking antifreeze
83,000 MILES • 6 CYL • FWD • AUTOMATIC
GARYKMON
when engine cold, need to shift between neutral and park approx 10 times before it starts. when engine warm its all okay
Mar 5, 2008 at 12:32 PM
SERVICE WRITER
  • 9,123 POSTS
2 problems?
Get the leaking antifreeze problem taken care of asap, fair chance of a leaking intake manifold, but just a guess based on common occurances, water pump is next guess....assuming this is a 3.1 motor. 3.8 motor, there is a 90 degree plastic hose that breaks by the tensioner.
The no start may be a nuetral saftey switch or the shifting of gears my just be ironic. A fuel pump may be bleeding back. Instead of shifting the gears, cycle the key from the on position for 5 secs. to the off position for 5 secs. Do this 4 times then crnak the motor..does it start right up? yeah? replace the pump.
Mar 5, 2008 at 12:47 PM
