2000 Buick Century shudder while shifting
2000 BUICK CENTURY
100,853 MILES • 6 CYL • FWD • AUTOMATIC
SPIKESPAL1
When the engine is warmed up, some shifts seem to hesitate or shudder. Brief research leads me to suspect the Throttle Position Sensor might be the issue. Question: will a TPS problem always trigger a "check engine" light? Or can the TPS be out a little bit, enough to cause transmission shudder, but not trigger the check engine light? Either way, is such a situation likely to cause transmission damage? Thanks, Doug
Aug 29, 2009 at 8:34 AM
  • 110,240 POSTS
Yes, a bad TPS should set the light. Is the trans fluid full?
Oct 2, 2009 at 6:34 AM
