2000 Buick Century noise
32,000 MILES • 6 CYL • 2WD • AUTOMATIC
RSALS1
a peeking noise in the motor , after it warms up it gets quit , but not completly gone . Could this be a big problem . I just bought the car
Apr 7, 2009 at 9:40 PM
SERVICE WRITER
  • 9,123 POSTS
peeking?
Chirping maybe?
May be belt glazing that can be removed by using valve grinding compound placed on different areas of the belt (while it is NOT running). if the noise stops after you start it, then it may be solved.
Other possibilities are a stretched belt, a weak tensioner of a pulley going bad.
Apr 7, 2009 at 9:58 PM
