low tire warning light reset?
69,000 MILES • 6 CYL • 2WD • AUTOMATIC
MLSCHRMR
tires are ok, have pushed the reset button on the fuse panel inside passenger side dash board but the light still refuses to go out
Feb 4, 2009 at 12:09 AM
AZHOMBRE
  • 6 POSTS
[quote:f18294b087="mlschrmr"]Electrical problem
2000 Buick Century 6 cyl Two Wheel Drive Automatic 69000 miles
tires are ok, have pushed the reset button on the fuse panel inside passeneger side dash board
but the light still refuses to go out[/quote:f18294b087]
Make sure the tire pressure is the same on all four tires, then push and hold the reset button for approx. 3-4 seconds and see if that works.
If not, then you have a faulty wheel sensor.
Jerry
Jun 20, 2009 at 6:28 AM
BRIANA2323
What if its not a faulty sensor?
Sep 16, 2022 at 6:23 AM
