2000 Buick Century help
TBARLOW3
Electrical problem
2000 Buick Century Two Wheel Drive Automatic 14000 miles
I have a 2000 Buick Century and the trac off and service vehicle light stays on the engine will not even crank. How do i fix this problem?
Mar 9, 2010 at 2:33 AM
  • 110,251 POSTS
You need to get a scanner and check the computer to identify where the light is coming on from. Most parts stores will do it for free, but since it doesn't run, you may want to rent or see if they will lend you one to use.
Mar 12, 2010 at 1:03 AM
