2000 Buick Century Engine overheating
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
HRN
I do not have any leaks in my water system on this car. Could the ratio of anti freeze to tap water cause a problem in overheating? Could the radiator need cleaning? Could the heater thermostat be the problem?
Any ideas?
Mar 8, 2010 at 4:50 AM
  • 110,251 POSTS
Any of the items you listed can cause it except the coolant to water ratio. It should be 50 - 50 but even straight water doesn't boil until 212°F.
Explaine what is happening.
Mar 12, 2010 at 2:01 AM
