1999 Buick Century water pump problem
100,000 MILES • 6 CYL • FWD • AUTOMATIC
MARCOXIV
Hi
A cupple of days ago a squeaking sound (like if something needed grease our something) seems to be coming out from the water pump. The car doesn't overheat our looses coolant but the sound continues. Does it mean the water pump is dying? could it be just the bearing in the water pump our something? (i am not really a mechanic...)
IMPORTANT :The car has been sitting for almost a year. It's only been back on the road 2 weeks ago. The engine coolant seems really durty. When I open the cap on the radiator, I can take durty stuff out with my finger. Could that be the problem? Do I need to flush and clean the hole system?
Thanks a lot, Marc
Mar 24, 2010 at 12:29 PM
  • 110,248 POSTS
Marc:
If it is making noise, it is the bearing. Eventually, it will start leaking from the weep hole under it. As far as the coolant, yes I would service the system.
PS: Make sure to use the correct type of coolant. If it has dex cool, do not mix any other type with it.
Apr 12, 2010 at 2:29 AM
