1999 Buick Century Sputtering
KIMBALLS611
Engine Performance problem
1999 Buick Century 6 cyl Automatic 60,000 miles
My car cranks up and idles fine. When i put it in drive and start to accelerate, it begins to sputter as if it can't get gas. It will drive fine one day and then malfunction again the next. i have changed the air filter and fuel filer and the problem still persists. any help would be greatly appreciated.
Jun 2, 2010 at 4:45 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 3, 2010 at 9:03 PM
