I don't know how much testing you have done, you may be way ahead of me on this, but, If none of the windows work, I'd check b+ and ground to the masterswitch, before I did anything else. My info shows B+ is yellow wire and ground is black.
You can also check the circuit breaker for the power window, see if the circuit goes hot when you turn on the key. Sometimes if there is a bind on the motor or the motor is faulty, when you try to operate, the breaker will be hot to the touch.
SPONSORED LINKS
Tuesday, July 29th, 2008 AT 8:50 AM
