1999 Buick Century grease in radiator
MORROW
1999 Buick Century
What would cause grease to get into the radiator?
The car is running excellent but will the grease cause any problems.
Why do I have to press the gas pedal after putting gas into the car before it start?
Sep 2, 2010 at 1:24 AM
WRENCHTECH
  • 20,760 POSTS
The first thing you'll need to do is determine what that actually is in the radiator. The only way grease got in there is if someone put it there. It may be motor oil or transmission fluid that coagulated in the coolant. Check your motor oil to see if you see any signs of coolant there.
Sep 2, 2010 at 1:50 AM
