1999 Buick Century FUSES DEALING WITH THE LIGHTS
143,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANDREW RABB
LEFT REAR LIGHT WILL NOT BLINK WHEN I USE THE TURN SIGN AND LEFT FRONT YELLOW BULB WILL NOT TURN OFF WHILE I AM DRIVING.SHOULD I REPLACE A FUSE? IF SO WHICH ONE?
Feb 10, 2010 at 7:36 AM
DOCFIXIT
  • 18,828 POSTS
Most likely fault is in turn signal switch
Feb 11, 2010 at 2:15 AM
