1999 Buick Century electric windows
190,000 MILES • 6 CYL • FWD • AUTOMATIC
4WAYHUNTER
i bought a 99 buick century, the car runs great but the windows wouldnt roll down i replaced the motor, regulator and main switch and still wont roll down or up. when you press down on the driver side button it just clicks. i checked the voltage and it was only 9 volts so what do i check next all help is appreciated.
Aug 12, 2010 at 1:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty retained accessory power (RAP) relay, behind glove box.
Aug 12, 2010 at 1:59 PM
4WAYHUNTER
what does it look like. the 30afuse has 12 vts when car is not running and 14 when ranked. i bet the one in the fuse box is not what your talking about.
Aug 13, 2010 at 5:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
will look similar to the pic below, it's a relay which is a bit different than a normal fuse.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2583.jpg
Aug 14, 2010 at 10:36 AM
