1999 buick century custom
1999 BUICK CENTURY
DA_ATX
i am trying to find the wiring that connects to the master window switch. at first i thought it was the switch but then i replaced it and still had the same problem where the windows wouldnt go up. but then i was told to remove the wiring and check it...well i noticed that the connection at the end of the wires was burnt where can i find a replacement
Feb 23, 2007 at 5:14 AM
CHEVY22
  • 1,375 POSTS
there is a relay on the right side of the dash , in the door opening i believe , the harness should , and i say that loosely , unplug in the door panel , it breaks off in all directions to each door and back to the dash , chev pont and buick should all be the same but they are all different, you may find it goes through the door , you can pull the panel and trace it , the dealer should be able to supply you with the harness, i have replaced them before , dont forget to check that relay , there is a reason for this problem , if you have an ohm meter you can check for resistance at the plug the input side and try and trace the problem down , it burned for a reason
Feb 23, 2007 at 5:39 AM
