1999 Buick Century
WSHENLEY
Electrical problem
1999 Buick Century 6 cyl Automatic
Power windows do not work. When I open the fuse panel the power window circuit breaker is getting hot to the touch as soon as I turn on the car.
May 23, 2010 at 2:11 AM
  • 110,248 POSTS
Eithere the CB is bad or you have a short. Remove the CB and try another one in its place. See if that takes care of the problem. If it doesn't, you will need to remove the driver's door panel and check for short to the main switch first.
Let me know what you find.
Jun 7, 2010 at 1:21 AM
