1999 Buick Century
1999 BUICK CENTURY
124,000 MILES • 6 CYL • 2WD • AUTOMATIC
ACRAINEY
When you first start the car and put into drive, it will try to cut out, spit and sputter until engine is warmed up. What can cause this problem?
Feb 18, 2010 at 7:01 AM
JDL
  • 16,098 POSTS
There are many things that might cause it. How long since a tune-up? Use a gage and check fuel pressure. Are there any trouble codes? Some of the national brand autostores used to check codes for free, also, they used to loan out a fuel pressure gage. I just wanted add, if idle issue, clean the throttle-body and check iac.
Feb 18, 2010 at 7:08 AM
