1998 Buick Century windshield washer pump
CJOKO
Electrical problem
1998 Buick Century 6 cyl Front Wheel Drive Automatic
My windshield washer pump stopped working. I installed a new one and still no help. I've put a voltmeter to the connector and when I activate the washer from the switch, I get 12V at the connector. I also applied 12V directly to the pump and that works but when I plug the connector to the pump there is nothing.
Nov 8, 2010 at 7:52 AM
DOCFIXIT
  • 18,828 POSTS
Chck the ground at connector
Nov 8, 2010 at 7:59 AM
JDL
  • 16,098 POSTS
Do you think the washer lines might be clogged? If problem is electrical, maybe connector is faulty? In the diagram, red wire is voltage, black is ground,
https://images.2carpros.com/forum/automotive_pictures/170934_windshield_washer_pump_1.jpg
Nov 8, 2010 at 8:02 AM
SPORTZNUT24
I have the same problem as cjoko. I also jumped the pump and it works fine. I followed the wires as far as I could see them from the pump. I was wondering where they lead after they combine with the main wire harness or is there a seperate fuse for the washer pump and the wiper motor?
Jan 15, 2011 at 4:11 PM
JDL
  • 16,098 POSTS
You have a 98 buick century? It would be best to make a new post.
Jan 16, 2011 at 8:16 AM
