1998 Buick Century Power windows
FRANKBEL
  • 1998 BUICK CENTURY
1998 Buick Century
My driver side power window doesn't work. How do I know it needs a motor or could it be something else?
Monday, January 18th, 2010 AT 1:50 PM
JDL
  • 16,098 POSTS
If the other windows work, I suspect the window motor or wiring circuit. Possible issue with master switch. I'd have to check voltage and ground at the motor.
You need to remove the door panel and see if the motor is getting power. If it is and still doesn't work, chances are the motor is bad.
Monday, January 18th, 2010 AT 2:20 PM
