1998 Buick Century power steering pump replacement
131,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVRENMOS
I went to start the car up one morning and everything was fine, but when I started in gear, the steering was very hard to steer. I checked the fluid level in the power steering pump and it was a little low. Can the pump go out with no warning?
Dec 27, 2009 at 11:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
normally the pump itself failing would give a warning (sounds, leaks etc..). have you checked the belt?
Dec 28, 2009 at 7:48 AM
