1998 Buick Century P0305 Code
POLARIS1MAN
Engine Performance problem
1998 Buick Century 6 cyl Front Wheel Drive 104,00 miles
Car was hooked up to a code reader at Carquest and came back with a P0305 cylinder #5 misfire. Engine light flashes.
Question is, if/after I change spark plug and wire, how do I check the coil pack for failure?
May 13, 2010 at 12:16 AM
  • 75,988 POSTS
A misfire on a specific cylinder-check the plug/compression and injector for that cyl.
May 13, 2010 at 4:21 AM
POLARIS1MAN
I ended up tapping on the #5 Injector, and must have cleared a piece of debris, as the car is running great again!!
May 13, 2010 at 4:40 AM
