1998 Buick Century leaks
14,800 MILES • 6 CYL • FWD • AUTOMATIC
BONSIM47
my car is leaking coolant underneath the passenger side by the front tire
Feb 13, 2010 at 11:55 AM
  • 110,251 POSTS
That is where the waterpump is located. CHances are it is leaking from its weep hole. Locate the water pump and under it you will see a small round hole. WHen the seal or bearing in the pump goes bad, it will leak coolant from there. CHeck for evidence of a leak and let me know what you find.
Feb 14, 2010 at 4:14 AM
