i believe i need to replace the fuse for my horn relay. where is that located?
Jan 18, 2010 at 4:13 AM
BLUELIGHTNIN6
✓Experienced Mechanic
horn relay is located in the underhood electrical center (mounted to right strut tower).
Jan 18, 2010 at 4:37 AM
JDL
Welcome to the forum. Horn fuse 15 amp, underhood fuse box. There is also a horn relay in the same fuse box. Usually the problem is the wiring circuit in the steering column, maybe you'll get lucky with the fuse?
