1998 Buick Century V6-3100 3.1L VIN M SFI
Blower Motor Resistor
Behind Center Of I/P (CJ2 Shown, C60/CJ3 Similar)
Remove or Disconnect
1.Right side instrument panel insulator.
2.Electrical connectors from blower motor resistor.
3.Loosen (do not remove) both forward mounting screws.
*Blower motor resistor opening is slotted as access is extremely limited.
4.Rearward mounting screw.
5.Blower motor resistor. Important
**Care must be taken when removing the blower motor resistor. The resistor is a ceramic card for (C60).
Install or Connect
1.Blower motor resistor.
2.Rearward mounting screw. Tighten
*Screw to 1.5 N.m (13 lb. in.) .
3.Tighten both forward mounting screws. Tighten
*Screws to 1.5 N.m (13 lb. in.) .
4.Electrical connectors to blower motor resistor.
5.Right side instrument panel insulator.
Feb 3, 2010 at 10:58 AM
