1998 Buick Century heat
108,000 MILES • 6 CYL • FWD • AUTOMATIC
TBEAR1955
the car will not continously heat, replaced water pump, thermosat, back flushed coil, the higher the idil the better the heat, otherwise blows cold
Jan 28, 2008 at 4:52 AM
BMRFIXIT
  • 19,053 POSTS
[quote:0c2239e7be="tbear1955"]Heater problem
1998 Buick Century 6 cyl Front Wheel Drive Automatic 108000 miles
the car will not continously heat, replaced water pump, thermosat, back flushed coil, the higher the idil the better the heat, otherwise blows cold[/quote:0c2239e7be]
it sound like a low coolant flow throw the heater core
Engine cool
lower the coolant level
Locate the two hoses running to the heater core
disconnect them at the engine side leaving hoses connected to heater core throw the firewall
use garden water hose and compressed air if possible
run the water and follow by air throw one side and out the other and vice versa
do that two to three times watching what leaving the heater core you are looking for the good flow and clear water to run throw
good luck
let me know
Jan 28, 2008 at 11:42 AM
TBEAR1955
just drove 1.5 miles to store and back, just about got back and it started to over heat, releived pressure and it started to heat, any thoughts????????????
Jan 29, 2008 at 7:17 AM
BMRFIXIT
  • 19,053 POSTS
[quote:0173070f8e="tbear1955"]just drove 1.5 miles to store and back, just about got back and it started to over heat, releived pressure and it started to heat, any thoughts????????????[/quote:0173070f8e]
it start to overheat with no or little heat on the inside
u release pressure and then you get heat
if so
you were running with low coolant
let it cool off and check coolant add as needed
you have to open air bleeders
Jan 29, 2008 at 9:38 AM
